TurboTA3.8
You wont keep up the pace
- May 24, 2001
Used Innovative MSBC complete with 2 solenoids and map sensor and c02 system to keep boost in check was uing it with a tial 46mm wastegate system managed boost flawlessly from 10psi to 32psi
co2 system includes rollbar mount, regulator,lines and fittings and bottle ,and complete set of instructions
The MSBC-1 Multi-Stage Boost Controller has been designed to allow the turbo charged vehicle owner to achieve the maximum vehicle potential in a controlled and repeatable manner. It has been designed to be a flexible electronic waste gate control solution for the performance street, dirt, and drag race markets. The MSBC-1 has the multi-stage and control flexibility produce repeatable, controlled boost profiles with a variety of turbo systems and applications in a cost effective and easy to use package.
The MSBC-1 can be used in many high performance applications that require incremental boost control. This might be using the MSBC-1 to provide low, mid, and high boost stages for your street or dirt vehicle or creating a separate stage for each gear in a drag race application.
The MSBC-1 has the following features
Up to nine stage programmable boost control.
0-60 psi target boost range for each stage (1 psi increments)
Five different ramp settings to control how fast boost is allowed to build.
Launch stage for drag racing.
Shift input for automatic stage selection for drag racing.
Front panel stage selection by driver for street or dirt use.
Readout of actual boost during boost control.
Two analog data recorder outputs - Actual boost level. Target boost level.
Two solenoid drive outputs - One increase boost output. One decrease boost output.
Can be used with single or dual port waste gate.
Uses electronic pressure sensor in manifold to monitor and control boost.
Will force waste gate to produce preset target boost level even with air density, load, or mechanical variations.
The MSBC-1 is an easy to use, cost effective tool to help you get the most out of your turbo vehicle.
575.00
575.00
