Jan 29, 2002 #1 T turbo6x2 10 second hot air Joined May 25, 2001 Messages 1,797 Just want to know what line to block off since the 85 has two lines and the 87 has only one. Is there any diagram on this or is it pretty straight forward?
Jan 29, 2002 #2 T TurboRegal84 Moderator Staff member Joined May 24, 2001 Messages 1,996 Use the line that comes from the Y.....the other line just goes to the vac block! I am pretty sure it will work...upon first WOT blast..take it easy to make sure everything is "ok"
Jan 29, 2002 #3 B Boost231 What's An Intercooler Staff member Joined May 26, 2001 Messages 16,740 YES on mine im running a 87 wastegate all i did is put a cap on the throttle body block where the second line goes. no probelm for me works good. and looks better then the 84-85 one to brent
Jan 30, 2002 #4 T turbo6x2 10 second hot air Joined May 25, 2001 Messages 1,797 thanks, Brent appreciate the input
