JDSfastGN
- Jun 16, 2001
I'm just wondering if this is common practice or if there are any downsides that I don't know about. I bought an aluminum "apply plate", to replace the crappy apply ring in the bottom of the drum. This in turn has left a little more room and I decided to try and shove another clutch in there. I used two .077 thick steels along with the rest being standard thickness as well as a backing plate from a spare forward drum. I have achieved .038 clearance using these but wasn't sure whether there was a downside to using the forward backing plate(since it is thinner). I figured since only a couple of the steels are slightly thinner that nothing would be adversly affected heat wise compared to if i had just used all thinner steels to acheive an extra clutch. Hope it will work. Thanks guys.
