Using WE4's cooler line temp tee?
Analyte
I have a turbo 400 and want to add on an auto. ultra-lite mech. tranny gauge. I seen you have a cooler line temp gauge tee that fits into the bottom return line. I would like to do this instead of welding on my pan.
I have aeroquip socketless -6an hose that I am using for my tranny lines. I have the 1/4 npt to -6an adaptor on the return tranny end that should work with you tee on your site. But my question is about using my mech. gauge. The gauge uses 1/2 npt fittings and I am not sure what size the female branch on your tee is. What size is it and is it for elec. gauges only or will it work with mech. also?
Never added a tranny gauge before and want to make sure I order the correct sizes so it all works and if I need another adaptor to use your tee then I need to find out what it is so I may get it from you also.
Kerry
The one on the site will not work for you. I can make it up for you. Give us a ring at the shop and it will be no problem.
Bruce
WE4
