Black Power
- Jul 3, 2006
Ok I am selling all of my nonstock performance v6 Buick parts. Keeping all my stock stuff. Here's what I have for sale:
TA Performance black "Brick" valve covers with grommets, K&N breathers and correct length bolts included. These are almost perfect, the only part that doesn't look brand new is at the back of the passenger cover, it rubs on the AC/heater box. Once installed on a car with the AC/heater box, you cannot see where it rubbed. Pics show where it rubs. Very nice valve covers! $140
Precision Turbo 6776 Dual Ball Bearing Turbocharger. .63 AR, 4" inlet, in great shape. Does not smoke or have any more shaft play than when I bought it. I put about 2000 pretty easy miles on it, never ran it more than 20psi. It includes the banjo bolts for the coolant lines, oil restrictor (pressure side), RJC style breather valve, and wastegate actuator. This is a $1335 turbo from gbodyparts, without the bleeder valve and banjo bolt water coolant setup. $1000 shipped.
Cam sensor. Worked great, I just pulled it from a running car. I am pretty sure it's an OEM sensor, not some copycat. $50
Cam sensor tool. Has an LED that lights up, then the light goes off as you get it set correctly. Works fine.
$15
MAF inlet pipe, it's a 3" pipe. It works great, but not for a show car. $20
$15
