vac brake conversion
meaclez
im converting my gn to vac brakes i already have the master and booster.
is there a way around changing out the brake pedal. and also how does the booster bolt up to the firewall.
thanks.
When I did the vacuum brake conversion I used my powermaster brake pedal, you'll have to line it up measure and redrill the brake pedal to where the hole should be.
