How do you know how to place the vac and boost line on a deltagate mark II. The line that is attached to the fitting next to the adjusting bolt goes into the car (knob turned boost controller) and the other fitting is tied into the gray "Y" fitting coming off the large metal line on the top of the intake. The line on the bottom of the wastegate keeps blowing off under boost and that line is the soft rubber hose. The other line is a hard plastic line. Also for my bov which is mounted on my intercooler pipe should it have a boost line or a vac line or basically where should I tie that piece into. I am having a vacuum line nightmare on my car. It has so many Pep Boy "T" fittings on it that it is ridiculous.
