Relocated canister under car looong time ago. Noticed recently what sounded like a vac leak from under car so I got under there (while running). Its coming from the bottom of the canister, which is evident when I cover the bottom of it with my hand and the sound goes away. The filter element is missing and I wouldnt be surprised if half the charcoal crap has fallen out aswell, since a couple pieces fell out while I was under there. Noticed that there is no check valve on the vac line to it either, just a straight hose. I am suspecting that all of this could be the cause of high BLM issues. I guess the solenoid is probably bad from not having a check valve? Is this why vac is going straight through, or is it because charcoal and filter are missing? Are there any other cars (i.e. 3800 vehicles) that have the same canister/solenoid setup that I could just snatch from the junkyard? OR does anyone know some part numbers? TIA
Maybe I can crush up some charcoal out of the BBQ grill and stuff it into the canister through the grate on the bottom, and just buy the solenoid and CV
