Not sure if this will help:
Once you've determined a vacuum leak is present, here's the easy way to locate it. Get a piece of 3/16" rubber vacuum line several feet long. Carefully place one end to your ear and move the other end around in the intake manifold area. The hissing sound of the leak can be clearly heard through the tubing and will guide you right to it.
Diagnosing Engine Miss
No leaks around the intake manifold? The next most likely suspect is the power brake booster. Pull the hose off with the engine idling and plug it with your finger. If the miss goes away, the diaphragm in the booster is leaking or the vacuum hose connection to the booster is faulty.
Troubleshoot Power Brakes
From this, it should be obvious that the vacuum booster needs two things to do its job: a good vacuum supply from the engine, and a good diaphragm. A vacuum supply hose that's loose, leaky, collapsed or restricted may not allow the booster to receive enough vacuum to provide the usual amount of power assist. Consequently, the driver will have to push on the brake pedal harder to get the same braking as before.
A restricted vacuum hose will cause boost to drop off when the brakes are applied in rapid succession. This happens because the blockage slows the return of vacuum in the booster.
To check engine vacuum, connect a vacuum gauge to the supply hose that runs from the intake manifold to the booster. A low reading (below 16 inches) may indicate a hose leak or obstruction, a blockage in the exhaust system (plugged catalytic converter, crushed pipe, bad muffler, etc.), or a problem in the engine itself (manifold vacuum leak, bad valve, head gasket, etc.).
The condition of the diaphragm inside the booster is also important. If cracked, ruptured or leaking, it won't hold vacuum and can't provide much power assist. Leaks in the master cylinder can allow brake fluid to be siphoned into the booster, accelerating the demise of the diaphragm. So if there's brake fluid inside the vacuum hose, it's a good indication the master cylinder is leaking and needs to be rebuilt or replaced. Wetness around the back of the master cylinder would be another clue to this kind of problem.
To check the vacuum booster, pump the brake pedal with the engine off until you've bled off all the vacuum from the unit. Then hold the pedal down and start the engine. You should feel the pedal depress slightly as engine vacuum enters the booster and pulls on the diaphragm. No change? Then check the vacuum hose connection and engine vacuum. If okay, the problem is in the booster and the booster needs to be replaced.
Vacuum boosters also have an external one-way check valve at the hose inlet that closes when the engine is either shut off or stalls. This traps vacuum inside the booster so it can still provide one or two power assisted stops until the engine is restarted. The valve also helps maintain vacuum when intake vacuum is low (when the engine is under load or is running at wide open throttle). You can check the valve by removing it and trying to blow through it from both sides. It should pass air from the rear but not from the front.
Replacing a vacuum booster is a fairly straight forward job. All you have to do is disconnect it from the brake pedal on the inside and unbolt the master cylinder. The pushrod that runs from the booster into the back of the master cylinder must have the specified amount of play, so check your service manual for the particulars. Most require a small amount of play so the master cylinder will release fully preventing brake drag, but some late model GM and Bendix applications have zero play.
