Vaccum Lines
boostin6
Gotta Love That BOOST!
Does anyone know where to get the vacuum harness that plugs into the EGR valve and solenoid??? And the bent hose that T's off to go to the check valve back by the firewall..
I've checked all the local auto parts stores to no avail...
There are 2 harnesses:
PCV, Boost Gauge - P/N 25536303
EGR, Purge, Fuel - P/N 25525671
I believe (check me, I'm not 100% sure) both are discontinued.
Somebody (I can't recall, it may have been Jay's) is reproducing the PCV, Boost Gauge harness as 2, separate lines. Anyway, I saw the reproduction lines at Norwalk last year, and perhaps elsewhere.
I believe (again, check me) the small, formed PCV hose is also discontinued. However, there is (or was) an alternative hose that works perfectly with just a little, simple trimming - P/N 10055808.
Suggest you post your needs in the Parts Wanted section.
