vaccuum line question
cooper
Please forgive my lack of technical terms.
I've finally got around to putting a 4.1 intake and Q-Jet on my 81 Regal (na). I can still read the vaccuum line diagram under the hood, but it doesn't show one thing.
I need to know what lines connect to the little thing on the intake manifold that has 2 ports. It's on the left side, foreward of the carb, screwed into the manifold.
I know it's a kind of temperature switch, but the correct name eludes me:confused:
Anyways, thanks for the help. If more info is needed, let me know.
Welcome back Cooper! :D
The 4.1 intake uses a differant configuration. That's a TVS, (thermal vacuum switch). Your '81 does'nt use it. Buy an oxygen sensor socket and remove it. Find something to screw into the hole for now. Use it later for a temperature gauge sending unit. Or look at my website and try my set up.
Meantime, click on the pic below of my emissions label. It's not in a very good condition but it's good enough to understand the hose routing. (I know it by heart). Any other questions just ask. I'll do the best to respond.
http://members.telocity.com/~familiadiaz/'81 emissions label.jpg
Thanks for the help.
Really good site, too. I just wish my motor looked as good as yours. Someday, I guess.
Now that I know what the little thing is (aka the TVS) I will definitely put a mech temp gauge in there. I've got the coolant sensor in front of the t-stat housing.
I was amazed at how easy it was to swap out the intake and carb. I really appreciate all the help you've given me both here and before.
All I need now is get a new cap/rotor/coil, t-stat, and a few more new vac lines. I can't wait. Hopefully by next week I'll have the $$ to finish. (Family before car....I can't figure my wife's priorities out at all :rolleyes: )
Thanks again:)
