Vacuum Block Hoses
scrobbyd
Ok guys any suggestions, I have superglued zip-tied every vacuum line on my car. But for the life of me I can't keep from blowing the first two lines off of vacuum block the ones closest to coil pack. I have been using Silcon hoses, which are already a PITA to get on whatever I'm putting them on. But any other hoses that I've found I can't fit side by side on vacuum block. What are some of you guys doing with this issue on the vacuum block because I can't seem to fine thin vacuum lines anywhere.
Thanks Again
i zipped lock mind i have not had any problem and i race my car so its holding very well
Are your hoses or vacuum block oiled? If so correct problem . My car has regular vacuum hoses although oil separator is in place.
