Vacuum block that someone made a bit ago that has 3 ports on each side?
V6UnderPressure
The Artist FKA Scott4DMny
Someone was selling on ebay, custom vacuum blocks that had three 1/8 npt ports on each side. I am looking for one of these. Anyone have a source?
do these vac blocks really work good?
cottons also carries one that takes 1/8npt fittings
Vacuum Block, Heads & Intake, ENG135 | Cotton's Performance Buick Grand National Parts & Service
v6sleepr , not sure what you mean "do these vac blocks really work good?" ...???.... its a vacuum block with no moving parts
it wont work with your stock vacuum steel lines , so youll need to do some plumbing of your own
it takes 1/8npt fittings of your choice on the port size or you can do 1/8npt to hose barb or to AN or even flare or invert flare if you wanted and you can use steel braided hose ensuring your important lines wont come loose , like the line to the fuel pressure regulator or your map sensor if you run razor alky or a speed density setup
i have the same block with the brass fittings i was a little reluctant to install it cause the bottom had a diff. configuration then stock it looked like i had to custom make the gasket and didnt want any vac issues
PM "Slowburn65" He was making one just like the one in the pics a while back. Not sure if he has any more, or is able to make them anymore....Guess you'll have to ask....HTH ---Keith
I just did a way with the stock block . and drilled the back of my intake so that I could hide a block under the coil pack now all my lines will be hidden it looks alot cleaner.
