BADASSOMAR
- Mar 30, 2022
So I recently did the conversion from the power master to vacuum and now having issues. The day it was completed I drove the car home from shop and while on the freeway doing about 75ish car was running fine, but when speed dropped to about 40 mph or so and I started to accelerate car felt like it was misfiring or bogging if that makes any sense?? After I got home I parked the car for about 3 days and when I went on a drive my pedals went to the floor and had no brakes again. Swapped master for a new one, did a bench bleed, did the brakes also and car felt fine stopping. Drove it a couple more days and then my pedal hit the floor again.
could my booster be bad??? Anyone had this issues before??? Also , car is still doing the misfire when doing about 45 mph after speed comes down. Also not sure why someone drilled and tapped the plenum when can had a vacuum block already?? Any tips or help is appreciated. Thanks
Omar
Omar
