Powermaster Reply
OK, thanks Scott W for that part number I needed that. heres the way I'm going to tackle the job. I don't believe tapping into the PVC hose or buying a special vacuum block is wise or ness. The vacuum tap can be placed in the side of the plenum. I'm going to drill & tap it it to 1/4 or 3/8 pipe in the side facing the booster using a 3/8 hose barb fitting . The brake pedal issue I believe can be solved by re drilling a hole in the proper location dictated by the push rod position. By the way while one is at it drill & tap a 1/8 pipe thread in the L/corner of the plenum to also accommodate a tap for the boost gauge or what other vacuum dependent accessories you may have. I have done this before ,it works & makes for a clean neat job.
