Hey guys , first off thanks in advance. I recently installed the vacuum conversion kit from Red Regal and so far so good. However I teed into the charcoal canister vacuum line and i only get good stopping power when the engine is at low RPM. If i feed the car boost then the pedal is nearly unpushable. You literrally would break the pedal trying to push it down. Is there a better place that i can tee into at least temporarily until i :redface: get a vacuum block. My pcvs have been replaced by breather filters so no luck with that. Please please please let me know asap. THANKS AGAIn.
