Swapped over to vac setup in the spring. Worked great. But last week or so my brake pedal has gotten really firm. Almost as firm as if you built the pedal up without any vacuum. I really have to put some weight into the pedal just to stop the car. Check valve is working properly. Not sure if it's the unit itself or just the master cylinder. Anyone have any problem with this. Car still stops but I'm getting a keg work out and it's just not enjoyable to drive.
