Hydroboost Vs Vacuum Vs Powermaster
I Looked At That Summit Booster. Those 7" Vacuum Boosters Only Deliver 450 Psi To The Calipers, "if" You Had Vacuum. I Keep Going Back To The Reason Buick Did Not Install A Std Regal Vacuum Booster On Their Pride And Joy Turbocharged Grand National. They Could Have. They Only Cost G.m. $12.00 On The Assembly Line. Oddly Enough, They Furnished Hydroboost On The 83-85 T Types. Those Are Are Still Working After 22 Years. Buick Tried The Powermaster As An Experiment, And Were Not Worried About The Car 20 Years Into The Future. They Are Out Of Warranty. They Could Not Know How Long The Motor And Accumulator Would Last. In 1984, The Hydroboost Had Already Been Proven For 10 Years. Why Would Anyone Want To Install A Power Brake System That Buick Refused To Use, And Can Not Stop The Car, With Only 450, Maybe 850psi To The Brakes. Is Anyone Willing To Install A Pressure Guage On The Master Cyl, And/or After The Prop Valve To See What Pressure They Are Getting To The Brakes, Especially When The Vacuum Booster Is Under Manifold Pressure. The Hydroboost Delivers 2000psi To The Brakes Even When The Manifol Is Under Pressure. 2000psi. What Beats That? The Car Stops Exactly As You Ask It To. The Rotor Heat Is Reduced Dramatically. Buick 'raced" Their Cars In The "grand National" Race Series. They Won. They Had A Hydroboost And Power Steering On The Cars. It's The Only Way You Can Plow A Car That Heavy Into A Turn At Those Speeds. O.k. So You Say, "i'll Just Get A Vacuum Pump". Guess What? They Have A 1/8" Port To Draw Thru. Can It Match The "volume" Of Air That A Large Engine Can Pull Thru That Hole? No. The Vacuum Pumps Are Noisy, Burn Up In 6 Months, And Cannot Recover The Volume Of Vacuum Draw That A Vacuum Booster Needs. When A Vacuum Booster Is In The Released Position, It Has Equal Vacuum On Both Sides Of Both Diapragms. When You Apply The Brake Pedal, Atmosphere Is Let In The The Rear Side Of Those Dias. Half The Volume Of The Booster Shells. To Allow The Dias. To Release, That Atmosphere Must Be Sucked Out By The Vacuum Source. This Would Work For One Application With A Small Vacuum Pump, And Then It Has To Work It's Little Heart Out To Build Up For A Second Application. In Traffic, It Can't. If You Remember The L88 Corvettes, They Had A Monster Cam, Monster Horsepower, And Very Little Vacuum. G.m Was Afraid To Sell These Cars To The Public, Because The Vacuum Booster Would Not Work In Traffic. They Did Install Power Brakes On Every L88 Corvette, Though. To Drive That Car Into A Turn At 160mph Without Power Assist, Meant The Car Wouldn't Make The Turn. The Drivers Had To Downshift The Manual Trans To Get Vacuum Up. They Knew That. Now, We Install Hydroboosts On Those Road Cars, And Even On Vipers. It Works. They Drive The Car In Deeper Before Applying The Brakes, With Complete Confidence. Unique Performance That Builds The Foose 572 Camaros And The "eleanor" Mustangs Has Decided It Is The Answer To The Supercar Speeds. You Have A Member That Claims His Car Would Creep At 0 Boost, Now He Can Hold 22lbs Of Boost With His Foot On The Brake With The Hydroboost. They Bolt In, And Use The Same Pedal As The Powermaster.
