Vacuum to hydro boost question
1984 t-type
Murphy's Law
Most post i see are from Powermaster to Hydro boost or Powermaster to vacuum related. My question is if i have a already vacuum converted car and want to go to Hydro boost what do i do with the brake pedal ?
Easiest answer is to change the vacuum break pedal back to the Power Master pedal since the PM brake pedal is same as what's needed to your Hydro Boost
Or you can use the pedal you have and put in a new post for the hydro boost.
Yes you could do that, but you can easily find the correct brake pedal for not too much $
