M & D Fairchild
- May 28, 2001
Speed Pro VS-739R
O.D. 1.264"
Max. Lift .480"
Closed Pressure 104lbs.@1.70"
Open Pressure 277lbs.@ 1.21"
Coil Bind 1.160"
Rate/Inch 353lbs.
Speed Pro-VS-677
O.D. 1.72"
Max.Lift .490"
Closed Pressure 80lbs.@1.70"
Open Pressure 200lbs.@1.25"
Coil Bind 1.150"
Rate/Inch 267lbs
Engine has 50K miles and is as it left the factory.
Any and all opinions are welcome.
O.D. 1.264"
Max. Lift .480"
Coil Bind 1.160"
Rate/Inch 353lbs.
Speed Pro-VS-677
O.D. 1.72"
Max.Lift .490"
Coil Bind 1.150"
Rate/Inch 267lbs
