Sorry if this is posted in the wrong place... Anyways
I've been having problems with my gn just backfiring like crazy at anything past 1/4 and just feels way too sluggish from what it used to be before I parked it... When I try and drive it I can barely get to 40 mph as it's just backfiring too much and won't rev out through the gear.
I don't have a full history on the car as we have had it 10+ years and the previous owner had tons of work done to it at connelys's in Houston tx
I've ruled out the maf sensor, cam sensor, crank sensor, injectors, fuel pump, compression, fuel filter, and the turbo does spin freely with almost no play...
Now sorry about the rambling but my question is if it is stuck in a valet mode, will disconnecting the ecu from the harness or disconnecting the chip for like ten mins then plugging it back in take it out of valet mode?
As stated I don't have full history, is has the factory alarm with the key code to start (yes I'm putting in the right code! Lol) and the chip is a mag4 from connelys's
Thanks for any help!
Leland
Leland
