Turbo1dr
9 Sec Wanna-Be
- May 25, 2001
...on second thought maybe you've seen this happen.
I have the latest and the greatest GN1-R's (full race ported 2.0 & 1.6 valves), T&D roller rockers and SOLID roller cam. Brief history: On the engine stand, I adjusted all rockers to .013. I installed the engine in my Malibu and I heard them clicking... normal I thought, no big deal. It runs fine and I've even drove it about 50 miles.
Fast forward to today:
I decided to check the lash so I pulled the valve cover on the drivers side and started adjusting them. The engine was about 120° when I started. Before I put the valve cover back on I cranked the engine and let it idle for about 2 minutes to check for tapping. I then rechecked the lash and it increased about .003. So, I re-adjusted them again and restarted the engine. Ran it for a few minutes and I cut it off. I re-checked the clearance again and the same thing happened. There was more clearence. Puzzled as to why this was happening (actually scratching my head), the engine had a chance to cool off but not totally cool. I then decided to set one rocker at a tight .006 lash and then started the engine. I run the engine for about 3 minutes and turned it off. I immediately got the rocker back to the same location to where I set the lash except this time the lash was .009! I stayed there checking & re-checking the lash with the feeler gauges as the engine was cooling down. As the engine was cooling down the clearences got tighter. You could actually feel the .008, .007, .006 feeler gauges get tighter between the rocker tip and the valve stem.
Everyone knows that metal expands when heat is applied so the gap should decrease but it's increasing instead. My diagnosis is the combustion chamber is actually "expanding" as it heats up and in turn, this causes the valve to become farther away from the rocker arm tip. If ANYONE near me would like to come see for yourself and confirm with your own eyes PLEASE DO SO! If you have a simular set-up as mine please post your experience. I'm an ASE Certified Master Technician so I have seen lots of unusual things in the automotive world. I have never seen this happen before on ANY car.
All the guys with the simular combination please post.
