Homemade breather kit
If you want to save money,like I did,All you have to do is pull out the stock oil filler cap-unplug the hose from oil stalk that goes to
Mass Air Hose(you probaly want to pull it right off and clean the inside,they get filthy)Now what I plugged the hole left over from the hose with the end off a walking kane.(Hey its the rubber piece on the very end,IT WAS FREE& IT WORKS
)Then you have to plug the little hole left on the oil stalk-I used a plastic cap from a spring water bottle!I used some clear silicone(I told you this mod is cheap!
,It fits real good and you cant even tell its there
This is the most expensive part you need a breather,I use a nice MOROSO PUSH IN BREATHER.I dont have the part number handy
but all you have to do is take your oil stalk and measure.I like the Moroso because it is cheap and looks good.Here is my list for a Hot Air breather kit.
1-Breather of your choice.
2-Caps for Air hose&oil stalk(filler tube)
3-A little clear silicone
4-5-10 minute installation
5-Very good mod for a little$$$,the most expensive is the breather,you want a nice breather,like a K&N ,MOROSO,ETC.
LET ME KNOW WHAT YOU THINK
P.S USE THE OIL STALK WITH PUSH IN BREATHER,DONT MOUNT BREATHER ALONE IN VALVE COVER,MOUNT BREATHER (PUSH IN)ON
OIL STALK(FILLER TUBE).
