Valve cover
Late 80's FWD Buick's V6's have them .... there's two versions ... one with the vent hole where the TTA have it (facing the intake) and another version with it on the short side so would face the firewall if installed in the TTA.
They are getting harder to find ... but they are still out there ....
At the same time I would grab the washers and acorn nuts as spares ... and you might want to grab some of the studs holding the covers in place as well if you need to modify some one day for roller rockers ...
These are supposed to be the correct ones for the TTA. I got mine from another TTA owner, collector a while back.
Yep the two pictured are correct for the TTA
The driver side vc (#25525799) are used on at least the following vehicles all 3.0L V6
1986 Oldsmobile Delta 88
1987 Oldsmobile Calais
1987 Buick Skylark
The passanger side vc (#25518546) where used on at least these (and the above) ... 3.8L V6
1987 Oldsmobile Delta 88
1987 Oldsmobile Cutlass Ciera
