Sep 8, 2009 #1 T TTipe Snake Skinner Joined Jul 25, 2008 Messages 767 What are some proven methods to clean up stock valve covers so they can be polished and cleared?
Sep 8, 2009 #2 P phillyturbosix Moderator Staff member Joined Aug 24, 2003 Messages 4,285 Sand Blast them and you'll be set.
Sep 14, 2009 #3 N need boost got boost? you should! Staff member Joined May 24, 2004 Messages 2,168 Good for painting but if you want to polish them I use glass beads, doesn't pit the covers so much. If you are just wanting to clear them , glass bead them first then wet sand them with 600 grit paper then your set. Good luck Daniel
Sep 22, 2009 #4 W whitecobra98 Member Joined Dec 6, 2006 Messages 738 i dropped mine off at a local guy...he bead blasted them then powder coated them.....super cheap and no work for me other than the drive
Sep 22, 2009 #5 A aminga Chicks Dig the powerbulge Joined Dec 15, 2003 Messages 5,578 Here's one that's been blasted with ground glass and coated with eastwood's bare metal powder (A high temp satin clear)
