quick85nat
6 shooter
- Jul 11, 2003
my 87 gn is running pretty well,i just have a smokeing issue,when i am on the gas it is fine but if i let off then gas it again it lets out a puff of blue smoke,its not all the time only when i let vac max out on the gauge then give it gas again,or if i cruising in 4th really low rpm almost idle doing like 40? it will smoke......im pretty sure its valve seals,not the turbo,or rings is there a better way to tell? i have taken the up pipe off and its pretty clean in there as far as oil is concerned
