ANY seal on a stock exhaust valve will do NOTHING. The stock exhaust valve has a groove on the stem, under the retainer. If you slide a seal over the stem (11/32") it will not seal on this undercut area. The groove is the valve seal, so to speak. It acts like an oil pump. It is tapered at the top, and has a sharp edge on the lower end. It pushes the oil up out of the guide. The undercut allows a certain amount of oil to enter the guide. It is really an oil metering device. If you have aftermarket stainless valves, then you will NEED to have the guides machined down and cut for positive seals. If you run a high lift cam (over .530") then there isn't sufficient retainer to guide clearance, either. (on the exhaust side.)
