Matt Weiser
It's an F.U.V.
- Dec 17, 2001
I'm changing valve springs (86 TR w/125k) and have one cylinder bank done. I'm using the compressed-air method. I noticed some air leakage apparently around the exhaust valve seats and out the exhaust ports on cylinders 1 and 5. Is this something to be concerned about? A recent compression check was good. Also, the leaking seemed to be reduced after I seated the keepers by tapping the valve stems.
Also, I had planned on replacing the valve guide seals with new ones from Poston's. But these were so obviously inferior that I left the stock seals in place. The Poston's seals didn't grip the valve guide at all it looked like they would move up and down with the valve. Very disappointing.
