Aug 17, 2003 #1 T TurboMike whatever Joined May 23, 2001 Messages 339 Anyone have the specs for the springs that come with the champion heads? I'm running a HR .525 lift and 224 duration. The springs from the old M&A wont fit, should I use the springs that come with the champ heads or order some different ones?
Aug 17, 2003 #2 M mayosmechanic Member Joined Jun 16, 2003 Messages 107 They are 100# on the seat.They are only good to .500 lift on a hydraulic cam.A roller or flat tappet requires a spring change.HTH
Aug 18, 2003 #3 H HighPSI Moderator Staff member Joined May 24, 2001 Messages 5,978 It's too late for you. But others should be aware the GN-1's can be ordered with any spring installed. You just need to specify when ordering.
Aug 18, 2003 #4 T TurboMike whatever Joined May 23, 2001 Messages 339 Maybe the customer that ordered the heads did...i'll check with him and see. Thanks
