That was my intention, or rather what started my quest to figure out what to do. I was looking at the springs on Johns site, and I hear about using stock late model LT1 springs, then I had a couple of comp cams numbers. Each option had its ups and downs with one of the comp cam numbers looking like the best option. I started trying to figure out what I needed to do "for real" insted of just changing them, which lead to the entire pre-load conversation (shims). Where I am now is getting a firm hold on the springs. I hear a lot of folks say "I used...." but I would prefer to get a "the correct answer is....". My question, to which I need the "correct answer" is what are the specs on the stocker so I can get an equiv. aftermarket replacement, that is assuming that an aftermarket replcement will have more consistant spec numbers from spring to spring when compared to a stock replacement set.
Like I said, I want to try and do it right because I know I will have more than enough of a chance to screw it up!!!
Brent
