There are several things that change this relationship between valve stem and rocker, valve seat[sunk seat or too many valve jobs]material taken off valve tip.This is one reason that I love, and a lot of people switch too ,is the small and big block chevy stuff, a lot of adjustability.You could fix that but like anything else in life just add money. You might be able to cheat system a little and install lash caps or try just a little different length pushrod,but if it were me I would try to find exactly where the problem is and address it, because as you said not much adjustability with this type of system. The one valve where the valve sweep starts is almost where it should be ending, you might try installing an adjustable pushrod too a little shorter than what you have on that valve and sweep it,I like to use gear checking compound as it is yellow and shows up great, if it works, pushrods are cheap, compared to alternative.
