Valve stem installed height?
V SICKS
84 turbo engine.. need the valve stem installed height and not the spring or retainer height.. think the heads have 8445 number on them..could check again if it would help.. THANKS.. mike
If you had the spring installed height you could figure out the other heights you need fairly easily. The spring installed height should be around 1.75in.
