TurboRussty
- Oct 15, 2002
allright guys on to the next step on the TR i will be going up top and would liketo know if anyone can provide some part numbers or good recommendations for the following job.
1.valve springs... i wanted to know if there was anything that is a direct replacement that does not need shims to fit on the stock heads also without needing any machine work done to the head to makem fit. i have heard alot about the 980-12 springs is this a good replacement for sotck i later would like to go to a 206 or 208 cam in the future which springs should i go with in this scenario but will also work with my stock set-up. (in other words i want to use the same springs later for future cam install).
also if they are double springs or if they have the dampners in them do i run these springs without them and pop them out or do i need to run without them.......
2. lifters anything recomended with any part numbers for same scenario as above.....
3. valve stem seals had a couple problems trying to find these for my lt1 but how about for these motors what is a good brand stock replacement w/ any p/n's.....
4. pushrods.... hoping someone can recomend clevite on these cause i have a good connection for these from my partner..... what part numbers if any also recomended for future cam install....
5.retainers please tell me i can use the stock ones if they are not banged up, and hopefully they will mount on the springs above with no problems.... (be great if i coud use the old ones..).
6. locks ...please let me know that you can also use the stock locks for these valvesprings this would make the mission a whole lot easier and wil my stock locks and retainers work with a cam set-up....
all of the above parts i would love to change for now on the stock set-up with the stock cam and then hopefully in the future i can pop ineither the 206 or 208 cam and still be able to reuse these same parts that will be hopefully lited fom above.....
please get back a.s.a.p. guys as i want to start rounding up the parts to get this project rolling.....
p.s. any prices or rough estimates would help dearly and especially the part numbers if avialable...
thanks in advance
thanks in advance
