various engine for sale
626, got your pm, but what do I need to look for to tell if its acdelco or not? and what about the other coil pack? what do I need to look for?
The ignition module can be identified by the tan colored potting material, the part number on it (25526449) and the black finish. I believe the 2nd generation module is identified by part #24503624 and was unpainted. Both are equally good and will work fine with the Caspers tester I have.
The coil I'm less sure of. But it looks like the known AC Delco I have both outside and underneath. I could be wrong but I was mostly interested in the ignition module anyway.
Hector, do you mean the small L shaped bracket pictured?
dalton, I'm drawing a blank on the ignition module flat plate bolts, I thought it was just 3 spider nuts that screwed onto the 3 studs?
I have a good working ignition module and coil pack I'll take $60 shipped (pictured)View attachment 276339
Yes and the compressor
I'll take the $30 coil pack in the picture.
Send me your PayPal, please.
Sorry, I'm not trying to cut in line, just thought it was up for grabs.
OP, let me know if it becomes available.
That would be the the coil and module, or the second coil pack, just to make things straight.
1980-ish parts:
Crossover Pipe
Downpipe
Flywheel
I have 2 nice flywheels, and they are both correct for the turbo engines, not the ones they put on the NA engines.
$60 each shipped to the lower 48.
I can post pics tonight
