Hi folks,
Changed the oil today and noticed that the oil appeared infused with a very fine brass (or gold in color) metal suspension. There were a few larger particles (think salt grain and smaller), but largely just a very fine gold tint to the oil. Metal does not respond to a magnet, hence my assumption that it's brass. Also noticed a haze on the oil that was not obviously metallic, but was not the usual.
I haven't yet cut the filter open to see if there's a gold mine in there.
I'm hoping folks can help me to put together a list of potential sources ; my inital thoughts on things to check:
* rod and main bearings
* cam bearings
* bearings in turbo
Any other ideas appreciated.
I suppose I'll start by dissecting the filter and dropping the oil pan to see if there's more fine grit there.
Thanks,
Scott
* cam bearings
* bearings in turbo
Thanks,
Scott
   Thats where the brass comes from
 Kinda knows a lot about thrust bearing failures, bearing analysis, and copper/bronze metallic stuff in the oil.
