Greg Drenovas
- Jul 15, 2013
So this is kinda weird, at least in my experience. So I had a failure today with the power master brake system. Pedal got hard suddenly while driving. So, from this site, I followed the diagnostic information and I believe I have a failure in the pressure switch. The pump will not run at all but the fuse was good. So I checked for brake warning light operation and found that it didn't come on with key on engine off. Therefore, I decided to push the parking brake to see if that light came on then. Not only did the brake warning light come on when I pushed the parking brake, but also, the pump came on with the ignition on. Vehicle running, as long as the parking brake was on and the brake light was illuminated, the pump would work as it should!! I still feel that I have a failure in the pressure switch, but I thought I might post this oddity to see if anyone else has noticed this with a pressure switch failure. Seems that is is not grounding, and maybe can pick up the ground for the parking brake switch when its on??? Also noticed a slight bit of brake fluid in the connector for the pressure switch, so I am leaning toward that as the most likely failure. Please post back if you think Im missing something or am down the wrong road.
