- Aug 6, 2001
I'm chasing down a strange issue. My alternator had approximately 12.3 volts at the back of the alternator and was not charging the battery. I replaced it with a brand new unit from Kirban's and now am getting about 12.5 volts and still not charging the battery.
After the fact I realized that my "volt" light on the dash wasn't lighting up so I tore the dash apart and removed the bulb assembly. As you can see in the attached photos both pieces look brand new and test for continuity.
I'm assuming that my charging issue is related to the volt light but now I cannot figure out why the volt light isn't coming on. All the other lights on my dash appear to work normally. Am I missing something obvious? Any suggestions?
