Hey all, heres what the car is doing: At WOT my volts are dipping into the high 11 volts area. I think this is causing my car top lean out. At the end of the track, my 02 volts are in the 720's. At the start of the track, they are in the 790's. My car is running 11.40's at 30psi using 65# injectors and a brand new Walbro pump. It was doing this when I had 009's and an older hp pump. I thought I was just maxing that stuff out so I upgraded the injectors and replaced the pump. Still doing the same thing! BTW...the pump is hotwired of course!
Looking at DS files, my car is going to 11.9 volts. Could this cause my leaning out?? I have a newer Caspers complete wiring harness, new Caspers ground and positive battery cables. I also have a ground strap going from the battery to the frame, and firewall to bell housing bolt along with the extended grounds. Also have changed battery and alternator. Would a volt booster help this? I just ordered one from Caspers. Any other solutions? I also suffer from very slow windshield wipers and power windows. Actually the windows are pretty much at average speed I guess.
Thanks in advance
Kevin
Thanks in advance
Kevin
