my convertor doesn't lock up. i get a VSS code when i dump the codes from the ECU - (i have the stock ecu and chip). i checked the brake switch and it works fine, i have 12v going to the trans - can the VSS cause the convertor to not lock up, or do i have to replace the TCC solenoid in the trans?
thanks in advance for the help!!
PS: my speedo acts totally strange - only reads below 5mph, when i go over 5, it drops to 0, it reads fine when at speed and i put it in Neutral, as soon as i put it back in D the needle drops to 0 again! very weird!!
