Hey guys. Looking to go faster. See my sig below for what I have and where I am. My thoughts are below, pretty much in this order.
Precision SLIC
RJC 3" DP (probably do these two at the same time)
Timing set, front seal, rear main seal (been putting this off and I need to just do it)
Next I'd probably do a new turbo, WBo2, injectors, and power logger at the same time so as to keep from blowing it up. Any thoughts? Am I even close to the right track?
I realize I can do the PL and WB at the same time as the DP. i just figured i'd save it for later due to the $$ amounts! The SLIC and DP are pretty expensive after all.
I'd consider porting the heads, but I'd prefer to keep from breaking the factory seal until absolutely necessary!
Precision SLIC
