WANT TO TRADE My STOCK GN PARTS FOR PERFORMANCE PARTS
Intercooled88s
Moderator
I'm looking for a front mount intercooler(don't need the piping), adj. fuel reg., walbro 340, 50lb or 60lb inj., MAF pipe, New .030 Forged pistons, 14 bolt or 20 bolt girdle, New ARP studs or bolts(Mains,heads, rod bolts), New .030 rings and .010/.010 bearings.
Here is a list of what I have to trade.
GN Spoiler(GM not after market) all 5 pieces $175
86-87 MAF $80
GN Front bumper $130
GN rear bumper $100
Alum bumper reinforcement $100 for front , $75 for rear
85-85 ECM $40
86-87 ECM $60
Kenne Bell Ram Air canister and scoop $40
87 GN good running 109 short block $700
87 Engine complete, has a rod nock $2000
Engine frame mounts $35
Turbo Link V4 $200 (complete in case, used only 2 times)
87 Grey T-type upper door panels in good not New condition, no trim pieces $40 for the set
Passenger remote mirror $40
Blackout door handles $20 for both
85-87 GN seat belt set(10 pieces) $70
Grey rear sail panels(panels around the quarter windows) for t-top car in great condition $40 for both
Grey Third brake light $20
86-87 dipstickand tube$40
86-87 Factory Oilfiller tube and cap $30
86-87 Scoop for airbreather $20
N/A crank std./std. $40
Fuel pump hanger/sender $50
Turbo gas tank $40
T-top bags $35
blackout wheelwell trim $50 each
109 Block $300
crank $325
.020/.020 Turbo crank fresh from the machine shop $150
stock 8445 heads needing rebuild $40 a set
84/85 to 86/87 conversion parts(all the original GN parts you need to convert over from 85 to 87) $1500
BQ coded GN transmission 48k $300
BRF tranny $500
Stock 200 4r tranny pan $35
Oil cooler adaptor with nut $35
Timing cover $25
Turbo rods(2 dot) $40 a set of 6
Turbo flex plate $25
Turbo oil pans $30 each
84-85 ECM $50
84-85 control module $50
84-85 up pipe(after market) $40
Steering box $40
GN sway bars $30 each
windshield wiper assembly $15
Complete heater box $150
Non Key locking t-top $90+shipping for the set
GN tail lights with blackout trim $100
Quarter glass with blackout trim $80
3 piece windshield blackout trim $30
3 piece rear window blackout trim$20
Black wheel well trim $50 each
Turbo plastic wheel wells $80 each
Any other blackout piece e mail me
GN hood $95-$150
AC lines $45
Turbo shield $30
84-85 GN intake $40
86-87 fuel rail $35
84-85 fuel rail $25
Any year injector harness $30
84-85 valve covers $35
86-87 valve covers $35
cam position sensor just the lower part(no cap) $25
84-85 MAF $45
84-85 turbo adaptor $25
84-85 crossover pipe $35
84-85 Alt $30
8445 heads $40 a set
84-85 engine wire harness $145
86-87 engine wire harness $175
Any other harness on the car e mail I have them all
86-87 Power steering pump $60
86-87 AC compressor $70
86-87 Belt tensioner $70
86-87 Alt. $60
86-87 Main accessory Bracket $80
84-85 Main accessory Bracket $50
Small plastic guide that holds the posi bat cable to the lower front cover $20
Blue dash pad $120
Chrome and gray strips on upper door panels $25-$35 each piece depending on condition
I have all the plastic interior pieces for a marroon or grey car with either t-tops or hard top .
Nice grey arm rests $15 for both
Nice blue passenger visor with lighted mirror $25
Alalog gauge cluster $50
Gauge surround $35
radio surround $25
Stock GN radio $50
T-TOP trim around the t-tops on the inside of the car in Red, Maroon, or grey , all 6 pieces $100
87 GN steering box $40
Power window motors or power lock motors $10 each
E mail me if you need a part not listed Fortune628@aol.com I most likely have it.
or CALL ME at 413 746 9668(If you get voice mail best to just call back, I dont get to my voice mail often)
All prices are PLUS SHIPPING.
Mileage was close to 100k . Shipping is $180 , that's in a crate truck freight(terminal to terminal or to a business).
