Wanted Power Antenna Bracket GM 22038589
MRP78
Need the power antenna bracket and screws that go on a new power antenna mast. Original mast has the bracket welded to it. I have a new mast but cannot get the finial off the top of the mast to slide repair cable out of the new unit so I can put that in the old one so I will need the bracket. New, used, doesn't matter just need one that will work. GM part number is 22038589 Please let me know if you can help.
It's welded?? I just pulled one last week and the mast bracket was bolted on the mast with two screws. I drilled the top of the antenna to pull the end piece through from the repair cable. If you have the old tip still on the antenna use a pair of pliers to pull it off. Mine was broken off so I had to drill the hole clean. it worked just threw some wd40 in there to help the antenna mast move up and down.
Originals were spot welded. If it's been replaced before it may have a bracket that screws or bolts on.
View attachment 178800View attachment 178800
i have one
see attached pics
$20.00 plus the ride
