This is a T-R 231 w/FAST which runs fairly well, but has a few issues. One is, when it's warm if it stalls at an intersection (AE problem) or I shut it off and immediately start back up, I notice the A/F is at 15.94 for a while (if it doesn't stall again for being too lean) until I rev it up a bit (may stall ?). (I'm restarting without turning the key off to avoid reconnecting the ECM so I can see the dashboard as soon as it starts, but I've tried turning the key off 1st also) Sometimes if it stays running and I let it idle for 20 - 30 seconds, it may run ok but then stall again when put in gear. Once I drive around for a while, it seems ok, but if I'm not carefull taking off from a stop, it may stall again. It seems if I give it a very short but quick amount of throttle from a stop , it may stall and it may not. I've messed with the AE tables for hours to no avail ! Sometimes it gets close, but never right.
Another issue is cold startup. It starts up and then stalls. This is normally afterstart fueling. How much afterstart enrichment % is typical upon startup at 60 deg air temp ? I believe mine is around 25% and then decays to 0 in about 1 minute. Obviously it's lower at higher water temps and decays quicker, but why the stall at first start ? I thought it may be the fact I have 2 external fuel pumps without a check valve and fuel pressure drops down quickly as soon as the pump stops. I've even changed the fuel pump prime to hold at 20 seconds, but it still happens.
It has a 70mm TB, 72 lb injectors, 3-bar MAP, 212 roller, stealth 72 turbo, WB is mounted 10-12" from turbo in 3" TH Downpipe, 3500 stall Art Carr non lockup.
Anyone have any ideas I can try ? Norbs ? I can send you my configuration or a log if needed
