Well, on a good note I was finally able to cure my high rpm stumble. Turns out one of my brand new Magnecor plug wires was bad and was the culprit...not happy
Anyway, I was doing some tuning last night and nailed it in 1st gear. Car reved a little faster than I was anticipating and I ended up hitting about 7062 rpms, both the FAST and my MSD are set to 7000 rpms max. At the time I hadn't known that I passed the limit but after this happened the car basically shut down as I was driving. The engine was still running but the gas pedal was ineffective and would seem to 'gag' the car if I would depress it. Vacuum gauge was well below 20"Hg while this happened. The car basically came to a rolling stop and then promptly died. Turned the key and it fired right up and everything was back to normal.
I am assuming the fuel pump was cut-off, or at least that's what it felt like. Does this sound like the cause or perhaps something else. Since I have the FAST piggybacked with my stock PCM is it possible that once the stock PCM saw 7K that it shut the fuel pump down? Very strange to say the least but it looks like everything is fine.
