Would a manual boost controller work for you? If you’re not familiar, the factory boost solenoid is disconnected and the “y” fitting and hoses removed. The manual boost controller (mbc) is connected to the turbo on the straight end and the 90* end is connected to the wastegate actuator. The mbc can be adjusted to raise or lower boost.
