wastegate actuator problem
87-TURBO-T
I'm trying to get my car finished, but ran into a roadblock today. awhile back i purchased a pt70, hd actuator, and th downpipe from a member who said they were all used together. i cant seem to get the rod to fit the flapper while mounted to the turbo. this is a 4"/3" turbo. does it take a different style actuator? the one i have has an extra little bracket welded to it. thanks
the hole on the rod wont fit the tab on the flap? or theres not enough movement of the rod to "reach" the flap?
if i use the 2 bolt holes to mount on the turbo, its at the wrong angle and too far away. if i use just 1 bolt its alot closer.
I Got The Same Problem You Need A Te Actuator It Has 3 Holes Incase You Have A Precision Or A Garret
