EyeTalk2Trees
- May 29, 2001
I'm pretty sure i have an adjustable wastegate on my car (84 GN) I've done some modding and want to put the boost around 18-20 psi and see how it goes. Only question...if you make the wastegate rod longer does that make less boost? or is it the other way around? I'm asking on a tipical adj wastegate how do you adjust it. I was getting on the highway and wanted to see how much it was set to, on my new guage it went to 23# before i let off, might be alittle much. I got a chip form Conley's a mini mag i heard they like boost but a non-intercooled running 23# with mostly stock parts...see sig
thanks
JoshZ
thanks
JoshZ
