May 1, 2009 #1 B bad V6 Member Joined Oct 9, 2005 Messages 952 What are you using to lubricate the wategate assembly on a Terry Houston DP? Should I use WD-40 or is there something that is better?
May 1, 2009 #2 pacecarta LOGGED OUT Staff member Joined Aug 1, 2003 Messages 9,722 nothing, anything you use will burn and cause binding
May 1, 2009 #4 1000MileStylez Black Sheep Joined Mar 25, 2003 Messages 1,258 what about permatex 2400 degree anitsieze? http://www.permatex.com/products/Au...auto_Permatex_Nickel_Anti-Seize_Lubricant.htm
