Wastegate dial
williamsGN
'Horse sneeze' addict
I have an external wastegate with a dial control to set the boost level. The dial is under the hood. Would there be a problem with moving the dial under the dash, as far as the fact it will require a long run of vacuum lines ? I don't know if it will cause any sort of wastegate reaction time problem by running the lines so far ? Any thoughts ?
I will work fine in the car. I had one mounted into the knee bolster. If you really want to adjusted the pressure often, then you should by a eletronic one that is much easier to use, and more safe.
Like the other guy said, go electronic if you can. If you want to run it in the lines all the way to the inside, get some high quality reinforced lines. There's a noticable difference in quality from standard and high end lines that'll transmit the pressure better.
