williamsGN
'Horse sneeze' addict
- Sep 20, 2007
I have an external wastegate with a dial control to set the boost level. The dial is under the hood. Would there be a problem with moving the dial under the dash, as far as the fact it will require a long run of vacuum lines ? I don't know if it will cause any sort of wastegate reaction time problem by running the lines so far ? Any thoughts ?
